Hi all!!
My new PC "cannot detect" third Display in Windows 10 although it working fine in my old setup. All Cables are perfectly working because I can do Dual Monitor with combination with different monitors regardless of output connector , the only thing I cannot do is to display 3 Monitors simultaneously .
Heres the thing I tried so far:
Windows Update ,
Enable/Disable driver Monitor in Device Manager
Uninstall/Install driver Monitor in Device Manager
Set the resolution of each monitor to 1360x768
Change BIOS internal graphic from Auto to Enable
Upgrade to Windows 11 (revert it to W10)
My PC Specs:
CPU: Intel i5 10400 (w/ onboard graphic)
Motherboard: Gigabyte H410M S2H ver 3
Ram: Kingston Hyper 2666 DDR4 2 x 16GB
SSD/HDD: Crucial 250 GB
PSU: Seasonic Core GC 550
OS: Windows 10
BIOS FB
Monitors:
Dell U2414H (HDMI)
Philips 163V5 (VGA)
Hisense 32A4GS (DVI to HDMI Cable)
Are new generation on Intel Chipset choosy on what Display output to use like in my case I m using HDMI and DVI-to-HDMI cable at the same time? My Dell U2414H has DisplayPort input and Im going to try to buy DVI-to-DisplayPort Adapter base on your opinion.
Thnx!!!
Windows Update ,
My PC Specs:
OS: Windows 10
BIOS FB
Monitors:
Dell U2414H (HDMI)
Philips 163V5 (VGA)
Thnx!!!
