Thor V2 Case Fans
Crimsonshadow
33
I have had the Rosewill Thor V2 case and I have had the stock fans in it since I got it around Christmas. I will put the fans that are supported below:
-Front 1 x 230mm Red LED Fan (pre-installed)
-Rear 1 x 140mm Fan (pre-installed)
-Top 1 x 230mm Fan (pre-installed) or 2 x 120 / 140mm Fan (option)
-Side 1 x 230mm Fan (pre-installed) or 4 x 120mm Fan (option)
-Bottom 1 x 120/140mm Fan (option)
I was just curious as to the best way to arrange these fans to get the best airflow possible. If new fans need to be bought, that is no problem whatsoever.
I have the same case, and I am going to be buying 3 140mm fans that put out a total of 103 CFM each.
Since there are a good amount of mesh holes in the case, it may be best to have a negative airflow instead of a positive one.
