Thoughts & advice on NZXT H5 Flow & Hyte Y40/Hyte Y60 fans layout/cooling
iv recently be thinking about a case upgrade for my first build
which is as followed
current build an spec
before the gpu upgrade my 1660 oc super triple fan never broke 52c under load an while i know the its a different type an series , i think that the fact that the power color has just two fans vs my older tri fan gpu an
my other builds gpu the XFX Speedster SWFT 309 Radeon RX 6700xt 12 GB Video Card which has three also makes a diff an would in the my case , i did try it out both in horizontal an vertical mounting an compared to the power color the temps
were a whole 5c lower horizontal mount & in vertical mount were 7.5c
which i know isnt super but aint crap either but the XFX Speedster SWFT 309 Radeon RX 6700xt
an why i could just leave it its intended for my 2nd build an has a matching waterblock ive yet to install , so the power color is staying in the 1st build
an now to my long winded question id like your Thoughts & advice needed on instead of getting a different gpu just want to getting a different case
with different fan cooling layout so recently i saw the new cases all have got me interested
the NZXT H5 Flow , Hyte Y40 , Hyte Y60
which do you'll think would be the best upgrade over my corsair 275 air
i like both the Hyte Y40 & Hyte Y60
for the mobo side fan intakes bottom fans an triple an quad vertical gpu mounts
which i think either being able to mount further into the case with the fan layout as followed
sides intake , rear as aio intake , bottom & top as exhaust would work far better then my current case
or get the NZXT H5 Flow an using the rear an top as intakes with the aio in the top front also as
intake an use the front two an angled front bottom'ish fan all as exhaust
so which of the three an my desired configs would be the best buy an layout
