[SOLVED] Thoughts on my first build, any advice?
PC Tailor
Herald
What is your main usage?
Monitor resolution and refresh rate?
I will add more depending on the answer to the above, but at first glance:
  • If it's an intel system, going for 3200 RAM won't make much difference, It's Ryzen systems where higher RAM speeds really make noticeable differences.
  • You could probably swap the Samsung SSD for a 1Tb Intel 660p for probably slightly less.
  • You can knock another 100/200W off the PSU. A good quality 650W would run most 2080 systems, a good quality 750W gives you more than enough including any overclocking.
logainofhades
Faster SSD, and graphics, for slightly less.
PCPartPicker Part List
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor ($359.99 @ Walmart)
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler ($139.99 @ Amazon)
Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard ($129.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory ($99.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($99.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card ($703.98 @ Newegg)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case ($119.99 @ Amazon)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($129.99 @ Amazon)
Total: $1783.91
Generated by PCPartPicker 2019-10-04 14:21 EDT-0400
Oct 4, 2019
5
Main usage would be gaming. I'd like to run most titles at high settings. For the monitor the refresh rate is 144hz and resolution would be 1920 x 1080
Oct 3, 2019
9
The kind of money you're spending? Go for 1440p/144hz or 4k, it's wasted on a 1080p display. You could get 1080 smooth as butter for waaaaay less. Shorting the parts list so you can afford a better monitor is a better plan than buying all this for a 1080 display.
It's a fine list but you're maxing everything out, might as well have a screen capable of displaying all the excess.
