tnt2 fan was dirty
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Well,
My tnt2 was making quite a lot of noise.
So I decide to take out the card and rip out the fan.
In doing so I damaged/broke the fanblade...
I looked at how it all worked and that it was dirty... blackstuff.
It turns out I could have easily cleaned and oiled it and then I ll bet it
would have worked just fine.
There seemed to be also some weird white sticky stuff between the gpu and
the 'heatsink'.
I have decided to not describe how I could have cleaned it since that is not
my job.
That's the manufacturers job.
I have thus decide to create a website to start boycotting:
1. Products with fans in them without a manual describing how to clean them.
( For now I just put in my tnt2 back since I doesn't seem to create that
much heat... when it dies I ll buy a fanless video card since I am getting
pretty sick of these fans without manuals how to clean them :p )
Skybuck.
G
Guest
Guest
You've got to be the biggest dumbass in this group
G
Guest
Guest
"tntkid" <tntkid@wownospammail.com> wrote in message
news:2gd22mF17djpU1@uni-berlin.de...
and your a troll. go hind under your bridge.
Ryan
551
lol saphhire has fanless cards, i think 9800 Pro
G
Guest
Guest
'midst all this rapier wit, how *do* you clean them? Can o Air?
My brother does IT at a library and bought an air compressor. But
isn't some dust too fine even for that?
Tim
1,833
"Travis" <travis_at_charbeneau_dot_net> wrote in message
news:gIednSqtsJbaNzzdRVn-ug@comcast.com...
I remove the card, move to another room, then blast the HSF with compressed
air (via the little straw) - enough to spin the fan. I then proceed to
clear of dust from the rest of the card then return it to the case.
Periodically the circuit board needs to be cleaned with a brush as a residue
will settle on them, residue that seems immune to vacuums and compressed
air.
Not sure if that's the best way to clean them but it has worked for me.
G
Guest
Guest
"Lance Ballantyne" <lballantyne@sbcglobal.com> wrote in message
news:Z5doc.47454$Bg.32036@newssvr29.news.prodigy.com...
Listen cock jockey, If your going to try and insult me at least use the
correct spelling.
