Question Too low performance with fps in games (especially warzone)
Dec 3, 2020
4
Hey guys!
This is my first post in this forum. I recently bought a gaming pc. all parts put together by myself. I play most of the time cod warzone with around 80-90 FPS on Graphic setting on low. How can i fix that? I really want that 144Hz mark.
MonitorAOC C24G1, 23.6"
CPU-CoolerArctic Freezer 34 eSports Duo CPU-Cooler, 2x 120mm, white
SSDCrucial BX500 CT480BX500SSD1 480 GB Internes SSD (3D NAND, SATA, 2,5-Zoll)
RAMCorsair Vengeance RGB PRO 16GB (2x8GB) DDR4 3200MHz C16 XMP 2.0 Enthusiast RGB LED-Beleuchtung Speicherkit - schwarz
GehäuseKolink Observatory RGB Midi-Tower PC-Gehäuse Schwarz 4 Vorinstallierte LED Lüfter, Seitenfenster, Staubfilter, Werkzeugf
Power supplyBQT BN297 be quiet! Pure Power 11 CM 500W
MainboardASRock B450 Pro4 AMD B450 So.AM4 Dual Channel DDR4 ATX Retail
HDDSeagate BarraCuda 2 TB HDD, interne Festplatte (8,9 cm (3,5 Zoll), 7200 U/Min, 256 MB Cache, SATA 6 Gb/s, silber)
LANTP-Link RE200 AC750 AC Dualband WLAN Repeater
CPUAMD Ryzen 5 3600 Wraith Stealth CPU - 6 Kerne 3.6 GHz - AMD AM4 - AMD Boxed (PIB - mit Kühler)
GPUPowerColor Radeon RX 5700 XT Red Devil - 8GB GDDR6 - Grafikkarte
Hey guys!
A 500 watt PSU might not be enough in this situation. AMD's minimum PSU recommendation is 600 watts for the RX 5700 XT:
https://www.amd.com/en/products/graphics/amd-radeon-rx-5700-xt
Hey guys!
Run userbenchmark and post the results webpage. it may reveal some issues with your system. https://www.userbenchmark.com/
Your RAM is running at 2133mhz. You need to turn on XMP/DOCP in the BIOS. RAM speed significantly impacts Ryzem performance.
Did it work?
I did the benchwork test again :)
UserBenchmarks: Game 95%, Desk 91%, Work 88%
CPU: AMD Ryzen 5 3600 - 89.8%
GPU: AMD RX 5700-XT - 102.8%
SSD: Crucial BX500 480GB - 74.1%
HDD: Seagate Barracuda 2TB (2018) - 110%
USB: WD Elements 25A2 500GB - 28%
RAM: Corsair Vengeance RGB PRO DDR4 3200 C16 2x8GB - 87.2%
MBD: Asrock B450M Pro4
Thank all of you guys helping me!
