Question Total shutdowns; no temp throttling, no visual indications of a problem
Jan 6, 2025
6
AMD 7800 xt
Ryzen 5 7600x
32GB Gskill RAM
850W GOLD PSU
ASUS ROG B-650e-I MOBO
I've been having an issue with my computer, really since I've got it. Where when I play certain games my computer will cut power. Most recently it's been an issue with Marvel Rivals or an even older game Warhammer vermintide 2. Oddly enough table top simulator has had this issue as well.
The weirdest part about it, is that I can play newer games like space marine 2, Stalker, pretty much any FPS or RPG game and not have this issue. And I can play these other games for extended periods of time as well.
I'm really hoping that my issue is with a faulty power supply or something of the like but i'm just not sure where to go with it from there.
Checking in event viewer I get a Kernal-power error 41 claiming that a shutdown happened due to a few issues.
850W GOLD PSU
850W is the advertised wattage of the unit. What is the make and model of the PSU and it's age?
BIOS version for your motherboard?
32GB Gskill RAM
Got a link to this ram kit you're working with?
Moved thread from Components section to Systems section.
850W GOLD PSU
32GB Gskill RAM
https://newegg.io/ff2346e this should be the build list lemme know if the link is goofed
If you look up the memory using the memory QVL option off of G.Skill's site;
https://www.gskill.com/qvl/165/374/1640229752/F5-6000J3636F16GX2-TZ5RK-F5-6000J3636F16GA2-TZ5RK-QVL
it doesn't list your motherboard. it should run, but I'd have picked up ram that had AMD's E.X.P.O advertised on it. If you wanted to stick with G.Skill's themselves, you could've looked at the Z5 Neo's which are meant for AMD's AM5 platform.
You're on BIOS version 1818, the latest;
is 3067. Flash to the latest, clear the CMOS, then enable X.M.P and see if that helps.
Reactions: Nlist63
is 3067. Flash to the latest, clear the CMOS then enable X.M.P and see if that helps.
Many thanks!
One more question for ya. I had mentioned in a DM to you that there has been reported memory leaks for at least one of the games I had listed. Could that potentially be the root of my problems? Or maybe the update of BIOS will just help the computer safeguard itself from something like that?
