The build:
CPU: Intel Core i7-12700KF 3.6 GHz 12-Core Processor
CPU Cooler: Corsair iCUE H100i RGB PRO XT 75 CFM Liquid CPU Cooler
Motherboard: Asus PRIME Z690-P WIFI D4 ATX LGA1700 Motherboard
Memory: Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage: Western Digital Black SN750 2 TB M.2-2280 NVME Solid State Drive
Video Card: Gigabyte GeForce RTX 3080 10GB LHR 10 GB GAMING OC Rev 2.0 Video Card
Case: Corsair iCUE 4000X RGB ATX Mid Tower Case
Power Supply: Fractal Design Ion Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Recording of a launch: https://streamable.com/6bp7ty
View of the GPU: https://streamable.com/osll2o
This is my first build, maybe someone's got the slightest idea where to look for the issue.
The computer launches, but there is 'no signal' message on the monitor. It shouldn't be a cable or monitor problem as I have already tested these.
When the power button is pressed, as can be seen on the video, both stock fans and aio sta rt spinning and light up rgb.
Memory sticks don't lighten up - possible culprit?
It also might be mention worthy that while GPU starts up, lights up RGB and its fans start spinning, as can be seen on the second vid, after just a few seconds spinning stops.
The power button is flickering.
No sounds what so ever coming out.
I see there was a similar thread not long ago, but unfortunately went unanswered :/
forums.tomshardware.com
Question - Power Button blinking, no display signal
Hi, I have recently bought an ASUS PRIME Z690-P, with an i7 12700KF, and have 8gb of DDR5 RAM with another 8 on the way. I have plugged in all the cables from the PSU to the mobo, installed all my parts, but when I attempt to turn on the PC, all the fans start spinning, however the power button...
