Trouble with HAF 922 help!!!
gamer1291
101
Hello everone i just bought my pc now. I bought HAF 922 as my cabinet and i bought gigabyte 890fx ud7,phenom ii x4 965 and i have VIP power supply of 600W but i have a problem the motherboard seems to be too lengthy and i am unable to fix my psu.
If i fix psu first then motherboard doesnt have space to fit.
else
if i fix motherboard first my psu doesnt have space to fit
please tell me what should i do does this cabinet supports this motherboard??
this is what happens when u don't research the mobo is and extended-atx motherboard the haf 922 only accepts micro-atx and atx as mentioned earlier get a haf 932 or any case that accepts e-atx form factor oh and why did u get that mobo if u can't do 3way sli or cf with that psu??
at the bottom but the motherboard is just on the edge the psu is coming over the motherboard there is very less gap between motherboard and the psu difficult to install please any advice i want to build my pc fast thank you for your help please continue helping me
Yes i already returned 922 and bought 932 but still i am unable to install my power supply its gets in the way when i install my motherboard how do i install both of them if either one gives trouble to other?
True but what do you mean the one i have is a POS?.Does this 932 have a specific requirements of psu like not all psu are supported on this cabinet?
pos=piece of sh*t
well its not the case compatibility. any atx psu should fit in the case. its just the quality of the psu in general. for example your lousy 600w has probably the case amount of power as a corsair 400cx 400w psu...
and it just is less stable and wont last as long and isnt as good quality
Ok fine i understand that my psu is not of a good brand or quality but atleast it should fit in the case right why is it bothering the motherboard?
Alright here are some pics showing less gap between power supply and motherboard and see the i/o panel the motherboard is not fitting to the i/o panel unless i remove my power supply and push my motherboard a bit downwards
[/img]
You obviously have not attached the motherboard correctly. Just look at the IO sheild, the connectors should be touching it and peeking out the back of the case. I would recommend taking the motherboard out of the case and start fitting it in again. You should do this; Put in the motherboard stand offs, put the IO shield in place, put the motherboard in so connectors are peeking out the back of the case, screw the motherboard into the stand offs, then insert the PSU into the case and connect it up.
There was no need to change the case, the 922 is a great case and it should have fit fine (unless you do have an extended motherboard but i think you have a standard ATX that would have fit).
That i know but to align the motherboard to fit the i/o panel i need more space which is blocked by my psu and if i fix my motherboard first then i am unable to fix psu
