I am not sure what you are trying to describe as an "E-cable"
I was referring to the Ethernet cable, but it is ok thank you for trying to help kanewolf, I had the isp come out to reattach the cable heads, and they redid the wire, which we did diy at first, we never did a cross wire, which was to prevent interference from power lines which was a little quirk we had no idea about, even though we followed the right color coding, it seems that was the issue it seemed to work for a while but now I have a different issue pertaining to an intermittent disconnect, which seems to be only on ethernet, or at the very least more prominent on the ethernet versus the alternative wireless connection I have available, I am trying to troubleshoot where the problem is coming from, but it is proving very difficult.
It's a different problem entirely, but just maybe you might know what steps to take?
I will be playing a game, any for that matter, and will have a 1-5 second disconnect, I've been thinking, maybe I was a bit rough with my gbe family ethernet port(Z170A Tomahawk from MSI)when talking with the technicians putting the cable out and in, but the issue only seemed to arise long after that point so it doesn't make sense that it would be that.
I've tried different adapter settings, like disabling Advanced EEE, green ethernet, disabling wake on LAN, and unchecking the let windows shut down this device, not in that order to say,but I'm rather bad at this, I've tried resetting the network adapter from the windows options, and downloading the latest driver for the gbe family controller, but to no avail.
Usually those two steps I did would set the options accordingly to the manufacturers default I would assume, I even yesterday, did a windows fresh start selecting delete all files from all drives(checking the two options that are there)and for some reason, windows left a whole load of things, like escape from tarkov, and a few other personal files, which I assume it should have deleted, and wiped all content from all drives, as I assigned it to do.
Really a bit lost at the moment, thanks again however.
