Compression fittings are easy to assembly with your liquid cooling But as tubing heats (there is transfer over time from liquid/water to tube) it will eventually will shrink leading to leakage.
In that case is it better to go for clamps or compression fittings. That's they only drawback so far about CF(compression fittings).Any suggestions?
PS:First time WC in future so I will get all my ideas sorted out.
Thanks.
Thanks.
