Turtle Beaches P12 microphone won't work
Beanobrad
First of all I'm using the headphones on PC. I know that they were made for the Playstation 4, but the should also work on PC as well. The actual audio from the headphones works fine, but the microphone doesn't seem to work at all on PC. It shows up under my recording devices, but can't be set to default. Upon using this website: http://www.onlinemictest.com/ to see if it would work, when I use the switch on the cable to turn the mic on, it makes the usual popping sound and a sharp spike on the chart before disappearing and nothing else follows. Any help related to this problem will help massively. Thanks in advance.
