Question twitch upload problem
May 9, 2020
22
hi my upload is 9000 and the twitch test server the upload speed is 5k and 7k .
I usually had more was at 9,000 the bitrate
Just because I made my line and I no longer have disconnections because I had a disconnection issue from yesterday when my line was made,
while everywhere my Upload is very good and correct on twitch it gives me less results here I show photos to understand what I mean.. with same router is the test what could be wrong???????????
this is photos
https://ibb.co/4dhfKSq
https://ibb.co/84z7pvD
Turn the upload rate down to say 3k and see if it works.
Your problem likely is you are trying to do something else on the connection at the same time as stream. Most games do not not use a lot but if you have very little margin. You add in things like discord or even a web browser own uses some upload.
Then again it could be errors on the line or some twitch problem.
May 9, 2020
22
i streaming in 6k is ok and is stable in sever with 8k but the others?
