[SOLVED] TWO USW-Flex-Mini's & UGREEN USB C Charger 40W PD Fast Charger
can i power two USW-Flex-Mini's
https://store.ui.com/collections/unifi-network-switching/products/usw-flex-mini
off this
UGREEN USB C Charger 40W PD Fast Charger, 2-Port 20W USB-C Power Adapter
https://www.amazon.com/gp/product/B08XQHMZHZ/ref=ask_ql_qh_dp_hza
without burning either out or the USB-C Power Adapter ?
I would think so. The spec for the Flex Mini is 2.5W max. I power mine via POE and it runs at 1.5W.
If you can, I would recommend POE on the uplink port to power the FlexMini. You can probably get two Ubiquiti 48V POE adapters on E-Bay for about the same $20 that the USB adapter costs.
off this
