G
Guest
Guest
Here's the bottom line, it simply won't POST when I start it, this is the
specifications.
-Tyan Thunder K7
-2x 1.53 Athlon MP
-2x Crucial 512MB Registered DDR + 2x Mushkin 512MB Registered DDR RAM
-Asus V8200 Geforce 3
-Creative Labs Sound Blaster Audigy Platinum
-Tekram U360 SCSI Controller card
-Adaptec 2100S SCSI Raid controller card (32 meg cache, 128 meg stick
wouldn't POST either! w/ 4 device 68 pin Cable terminated)
-2x Quantum Atlas10k SCSI 36.4GB HD
-Plextor UltraWide 40x SCSI CD-ROM
-Plextor PlexWrite 12x/10x/32x SCSI CD-RW Burner (50 pin with Startech
50-68 pin adapter[terminated])
-3x Delta 80mm 68CMF fans
-Sunon 120mm 109CFM fan
-2x Thermalright SK-6 w/ 80mm fan adapter using Delta 80mm 68CFM fans
-Panasonic 1.44 3.5" Floppy drive with 32" floppy cable (the Tyan Thunder
K7 has the floppy connector at the bottom of the board and my floppy goes
on top of the tower case)
-In-Win 500 Full tower server case w/ Delta 460W AMD approved Power supply.
Ok, enough with the specs, time to move on to what I did, and now what its
doing. (Which is nothing)
I finally put up and booted the system for the first time friday and I've
been working hard on getting it working, with no success. I turned it on
and setup my Raid to use my 2 quantum drives in RAID-0, I then went into
the Tekram bios setup to make sure it was setup properly and it was. Next
thing I did was go into the main BIOS and disabled IDE, changed the AGP
memory and boot order options so CD-ROM was first in line. I then put in my
Windows 2000 Professional CD in my CD-ROM and booted from it correctly, I
hit F6 on load up and then put in my tekram and adaptec floppy's in and it
seemed to detect them correctly. I partionion my disk to make 1 partion and
then formated it (in the blue screen, not FDISK as DOS cannot see my SCSI
card or support RAID). It then copied all files to the HD (phase one: dos
copying). After that it booted and started detecting PNP items. When it
hits the section where it adds start menu items it prompted me 3 times for
the Windows 2000 CD, which it was already in there, it went th
rough copying those fine after hiting ok, then the next step went fine
(registering components), but when it came to saving settings it froze mid
way (the mouse would still move and numlock on KB worked, but it wouldn't
save anymore... and I left it there for 2 hours). I then decided to try and
reboot the system and retry that section, but this time it froze up 1/4th
the way on the same step. so I thought I would try again... but this time
it couldn't detect my cd-rom anymore so I had to restart the whole
installation.
I then restarted the installation by formating the partition and copy the
dos files back onto the HD, but this time it gave me a blue screen of death
half way done copying, so I said to myself "uh oh", and I then tried the
same thing again 2 more times giving me the same error. I tried removing
the sound card and geforce and then use the built-in video card and it
still did the same thing. So I then thought of trying Windows XP, and this
one gave me the same error, except this one got to 98% done copying files
until the BSOD came up. I then tried windows 2000 again, but this time it
wouldn't boot off the Cd-rom or floppy, it said IO disk error, so I tried
getting a new set of floppy disks and it said the exact same thing, so I
tried using a known good floppy drive and it still gave me the same error.
I then went into the BIOS to re-enable IDE and then rebooted the system and
turned it off to unhook the tekram and raid card so that I had no
peripherals causing any havok. I plugged in my known good Pioneer 16x
DVD-ROM drive and tried booting from that and it still said IO disk error,
so I took out the IDE CD-ROM and put the tekram and raid card back in and
tried booting up and it wouldn't turn on or POST. So I unplugged the floppy
drive from the board thinking this is what was causing the problem because
of the IO disk error, so sure enough I unplug it and turn it on and it
POST's and boots up, but I wanted to go into setup to disable IDE because I
have no need for it. It went through the POST for both the raid card and
tekram and then it froze up on entering setup for the BIOS, so I had no
choice but to reboot it and try again, but this time I got into the BIOS
setup and then went down a few options down to disk type support and hit
enter to view the available options and it froze right in the BIOS, so once
again I had no choice but to reboot and try again, but it wouldn't POST
this time. So I unplugged the tekram and raid card and tried again, but it
still wouldn't POST. I then unplugged the extra fans and hard d
rive power outlets and cd-rom's thinking it was sucking up too much juice,
but it still wouldn't boot or POST. What I mean by not booting or POST'ing
is that there is no video or keyboard responce. I then looked in the Tyan
Thunder K7 manual and found out that jumper J21 to reset the CMOS battery
is supposed to be defaulted on 1-2 for normal, but my board was defaulted
at 2-3 for clear. So I decided to try to put it back to 1-2 were it should
be and then bring it to 2-3 for 3 seconds back to 1-2 to reset the CMOS
(Keep in mind that the computer was completely unplugged, video, mouse, kb
and power as the manual suggests) and it still would not POST. I then
though maybe the board was shorting out (which wouldn't explain why it
worked before but ok, I still tried it) I removed several mounted screws
from the back panel and it still wouldn't POST (as I thought it wouldn't).
And that's where I am now... Stuck in limbo not knowing what else I could
try. I think I received a lemon (a dud board), but that's just my
professional opinion. 😉
If anyone has any comments or know what else I could try I would be glad to
hear them out.
P.S I am at work right now and I have planned to try to remove the 4 sticks
of ram and use only 1 processor & 1 stick of ram to see if it will post, if not then I will
ask for an RMA from the OEM I got it from unless someone else has any other
suggestions as to what else I can do
specifications.
-Tyan Thunder K7
-2x 1.53 Athlon MP
installation.
hear them out.
