What degrees celsius should I be running my Tbird at? I just got it and was looking at the bios. It says I was 72 degrees Celsius.
That sounds high.
WHat should I be at? Also, How long does it take to burn one out? I was trying to get my comp setup and only used it for about a total 'on time' of maybe 25 minutes, and now it wont start anymore. I didn't change a THING, I just powered it off, and then went to power it back on, and now the mobo gets power but nothing happens... no video or anything. I tried to reset CMOS jumpers like 10 times but nothing happens.
Ok so whats wrong? Did I burn it out? Defective CPU/Mobo? I think that this is the second time it happen, because I had this problem before... see, I was starting my comp, and mobo beeped at me and wouldnt start. I kept changing settings and powering back on. I did this alot. Then all of the sudden I did it and nothing happen anymore, no beeps at all. So i took it back to the shop and they tested the proccesor and said it was dead. I got a new one and brought it home. Mobo beeped again. Swapped mobo. Now it worked. Came home fooled with it, now the thing wont start anymore.
Also, what should i have for a hs/f. At the place they sold me a:
Cooler Master DP5-6H51. It says on a little label on the box "cooler master socket A, 3 wire fan up to Duron 850MHz / Tbird 1.2GHz". Is this ok?
Also, again I ask, whats normal operating temp for Tbird 1.2GHz? My mobo is KT7A-Raid BTW.
Thanks for the help,
Danny
That sounds high.
Danny
