Thanks. Is there any harm in going for a CAT 8 cable. I know most homes won't make use of it but the price difference for a 1m cable is so minor I thought might as well get it if there is no draw backs in connection and speedCat5e or Cat6 cables are usually solid choices for most home setups. If you're looking for reliable brands, you can't go wrong with options like Belkin, AmazonBasics, or Mediabridge. They offer decent quality cables at affordable prices.
Now, remember that cable length also plays a role. Try to keep it as short as possible, as longer cables can sometimes introduce signal degradation.
Was a little suspicious why data centre grade cable was being sold like it was candy.There will be a major price difference in actually certified cat8 cables. Almost everything you find on the internet is fake cables. It is very hard to know who sell real cat8 cable. It is only used in data centers where they need 40gbit. Like all things used in data centers it is expensive stuff...think about 10 times the cost of a similar cat6a cable.
If you are talking patch cables just buy cat5e. They are easily replaced when you get equipment that needs more than 1gbit. The ends are fairly easily damaged so you might replace cables. Cables you run inside the walls you might consider cat6a.
What is key is the cable must be pure copper (no cca) it also must have wires 22-24 awg (no flat or thin cables).
Read the fine print and do not buy any cable that you can not clearly find this information. The vendor that sell quality cable know about all the fake cables and want you to know why you pay a bit more for real cables. Copper metal is expensive.
Monoprice tends to be a brand of cable you can find in amazon on the uk. Be careful even they sell those thin cables that you should not use.
You generally only need cat5e for home use.
Cat5e is rated to 1gbit at 100 meters. It can also run 2.5 and 5g.
Cat6 is a dead standard since it was invented. It is was to carry 1gbit over 2 pair or wires but nobody built devices that did that. It can run 10gbit at shorter distance. Since there is little difference in price to cat6a you should use that if you have 10gbit.
Cat6a is the main cable used for 10gbit and can go 100 meters
Cat7 is a standard that was never finalized that runs 10gbit. It provides no advantage over cat6a but is more costly.
Cat8 is only really used in data centers but if you want bragging rights with your friends and can find real cat8 cable it will do 1gbit just fine.
Anything else you see like "cat6e" are made up names and indicate it is a fake cable.
for this short range, you dont need any fancy cable, even CCA is sufficient, for longer ranges you will need proper copper cablesAny suggestions of specific wires that meet the pure copper 24 awg spec? Only needs to be 1m or 2m - a lot of the ones I've found are for 10-50m
