[SOLVED] Ultra wide monitor
gneius
39
I'm looking for a free sync ultrawide monitor for my pc
Dark hero 5
Dd4 64gb
Samsung pro 1 tb
Sapphire nitro plus special edition plus
Thor 1200 w platinum
Ryzen 9 5900x
Maybe I'll add some hdd or ssd
Probably a liam li xl dynamic and a Aio
Well, Ultra-wide means you're not really at 4K, which is defined as 3840x2160, but instead at 3840x1600.
That said, I think that a 3440x1440 resolution would be just fine for gaming. And, the GPU won't have to work as hard to get higher frame rates. After all, the more total pixels, the more work the GPU has to do.
There are plenty out there - but because monitors are so subjective (what my eyes like isn't necessarily what your eyes like), I would STRONGLY suggest trying to find a place that keeps a lot of monitors on display. See what feels comfortable and feels right for YOUR eyes.
What video card specifically? I think Sapphire used the name "nitro plus special edition" on a few different chips. I seem to recall RX580 and RX590.
What resolution are you planning on? Ultra-wide is available as:
  • In 21:9 (or close to that) aspect ratio, these are the most common resolutions
    • 2560x1440
    • 3440x1440
    • 3840x1600
    • 5120x2160
  • In 32:9 aspect ratio
    • 3840x1080
    • 5120x1440
    • 2560x1440
    • 3440x1440
    • 3840x1600
    • 5120x2160
    • 3840x1080
    • 5120x1440
6900xt ....ooopsss my bad ....
