Question Unable to set fan speed ,ROG RTX 2080
Feb 5, 2020
Hey,
A couple of weeks ago my GPU started acting strange, whenever the card reached about 70c the fans would speed up to 100%(about 3500 RPM).
What I tried to do:
*setting up a custom fan curve using asus gpu tweak and msi afterburner (normal version and the beta).
* Tried reinstalling the nvidia drivers while using DDU.
*Tried using NVIDIA Inspector.
*Tried getting older drivers.
All of the things I tried didnt help.
Then I tried setting manuel fan speed and found out that the GPU doesnt ignore the settings untill it reaches about 70c.
I cant figure out what the problem is and I cant fix it.
Thank you for helping in advance.
RMA the gpu.
The problem may actually lie beyond your ability to fix.
The fact that every time the gpu core temp hits 70C+, the fans will max out, tells me that something else - either the VRMs or the memory, maybe both - is actually running much hotter and likely thermal throttling.
