Hey guys,
So my issue is this:
In my previous build I had an AIO cooled i5-7600k and a EVGA 1070 SC all powered by a CXM 450w PSU. I was getting decent frame rates (usually around 60+fps on The Witcher III) on a 34" 1440p Ultrawide monitor on High-Ultra settings.
I recently upgraded that same rig (system specs below) to an i7-7700k and a Gigabyte 1080 G1 Gaming and am getting horrible frame rates (usually less than 45fps on The Witcher III) on the same settings and monitor.
I am well aware that the recommended PSU wattage for that card is 500w and I plan on upgrading but before I do I want to know if the underpowered PSU could be the reason for the poor performance out of that config. If that's not a possibility, then there must be something wrong with that card because there is absolutely no reason a 7600k/1070 should perform better than a 7700k/1080.
Any help is appreciated and thanks in advance!
SPECS:
GPU: Gigabyte GTX 1080 G1 Gaming (8GB)
CPU: i7-7700K
Cooler: Corsair H55 AIO
Memory: 16gb (2x8gb) G.Skill TridentZ RGB (DDR4-3200)
Motherboard: Gigabyte GA-z270MX Gaming 5
HDD: WD Black 256gb M.2 NVME/ 2x 500gb WD Black 7200rpm drives (RAID 1)
PSU: Corsair CXM 450w (Semi)
Fans: 3x Corsair HD120 RGB fans
SPECS:
CPU: i7-7700K
