I want to install a 140mm rear fan, i have a NZXT H7 flow case and i was looking at a NZXT 140mm fan
I found the NZXT F140P V2 and F140Q V2. the main differences in specs seem to be airflow and pressure
The F140P specialises in Static Pressure, has airflow rated at 93.2 CFM and air pressure rated at 4.45 mm H2O
https://www.scan.co.uk/products/nzxt-f140q-v2-quiet-airflow-fan-white
The F140Q specialises in Airflow/Pressure, has airflow rated at 102.9 CFM and air pressure rated at 1.7 H2O
https://www.scan.co.uk/products/nzxt-f140p-v2-static-pressure-fan-white
I dont understand the relative importance of these details so i cant work out which would be better for my needs. Pls can anyone help explain what the practical implications are of the differences between these fans, and which would act better as a rear exhaust? the H7 Flow case is pretty airy with lots of space so my gut reaction is perhaps i only need the F140Q but i dont understand the implications of the technical details. they are both priced the same so it doesnt seem to be that one fan is better quality than the other.
any help appreciated
