Undervolted 5v USB Fan
Munchbot
299
Hello, everyone,
I recently found this on amazon:
http://www.amazon.com/Phobya-USB-3-Pin-Adatper-30cm/dp/B00A5TFJ34/ref=sr_1_1?ie=UTF8&qid=1387088726&sr=8-1&keywords=phobya+usb+to+3-pin+fan+adapter+30cm
Would this work with a standard fan? Would I burn a USB port because the fan would use too much electricity? The fan I'm planning to use is the back fan from a Corsair 500r, which is a pretty standard 120mm one. (Although I can't find the exact RPM/ power draw)
Also, what is the amount of power I could draw from a standard USB port?
Thanks in advance!
According to wikipedia, USB 2 max power is 2.5w, USB 3 is 4.5w. Depending on how your motherboard / case is set up, what other devices you are using etc. other devices may or may not be using some of the available power.
Typical 120mm fan power is around 5 watts @12volts, some much more, some a bit less. At 5volts (USB voltage) the same fan would use around 2.1watts. ([5watts / 12volts] x 5volts). Therefore, assuming the full power is available it should be OK to use.
The fan will run much slower at 5 volts though, and may not even start up under its own steam (might need a poke to start spinning).
I would recommend using a molex to fan adaptor if possible, take the power direct from the PSU and theres no extra drain on the mobo.
Thank you very much! I was actually planning on making a USB desk fan using an adapter and two fan grills. Thanks for the information!
