Unidentified network when using ethernet connection
Choupina
Hello, I've been using an Ethernet connection for a while now and didnt have any problems, now i can't connect as it keeps showing unidentified network. I am running Windows 10. My ipconfig /all is below.
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-19D2VEE
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Ligação de Área Local* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 12-16-D8-02-70-AF
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 38-EA-A7-D9-28-58
Link-local IPv6 Address . . . . . : fe80::8d4e:b99b:3196:ebb9%8(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.235.185(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 137947815
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-23-A3-5C-86-85-06-37-5D-F4
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Qualcomm Atheros QCA9565 802.11b/g/n WiFi Adapter
Physical Address. . . . . . . . . : 20-16-D8-02-70-AF
Tunnel adapter isatap.{715F9AB0-453F-4044-B7DF-061BA0FCBC7B}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Hi there,
There are two things that I would try to start:
1. Try restarting the router. This is always a good place to start when having network issues.
2. Try running the command "ipconfig /release" and then "ipconfig /renew". This will release your network adapter, and request a new address from your router.
If neither of these work, then look into further steps.
~Agent :)
Hi there,
~Agent :)
