Unlocked AT&T Cellular 3595 on Cingular Network Problems H..
G
Guest
Guest
Archived from groups: alt.cellular.cingular (More info?)
Have an unlocked 3595 that works fine for calls but can't seem to get
the GPRS end working (no icon on screen). Downloaded some graphics but
can't connect. Spent hours with tech service with no help, any ideas?
Also can't determine what the security code is, tried 12345 and some
others with no luck, old owner doesn't know. Have Logo Manager but it
reports code is unavailable.
Check your WAP or GPRS Profiles. Must likely there setup for AT&T's servers.
