G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware,uk.comp.homebuilt (More info?)
In article <1dbbyz1kb658q$.1y082gck140j3$.dlg@40tude.net>, "Bob@see-
below-for-address.com" Bob@see-below-for-address.com says...
> On Wed, 11 Aug 2004 22:21:25 -0500, David Maynard wrote:
> > Bob@see-below-for-address.com wrote:
> >> On Wed, 11 Aug 2004 14:40:08 +0100, Derek Baker wrote:
> >>>I see in the manual for my new motherboard - an MSI K8N Neo - it says to
> >>>remove the power cord when inserting and removing cards and DIMMs.
> >>>Is this good advice or excessive caution? With my current board I never did
> >>>that.
> >> Plug the PC power cord into a "power strip" that is plugged into the
> >> electrical outlet. The "power strip" is turned OFF. Your PC is grounded,
> >> but it receives no current. Any suggestion that you remove the power cord
> >> is, of course, ridiculous, since there is no grounding path.
> > No, it isn't 'ridiculous' because there is no great over-riding cosmic
> > significance to having the 'earth ground' connection. What matters is
> > everything being at the same potential, whether it's 'earth ground' or not.
> Except that there is no guarantee that everything is at the same potential.
There is if you touch everything to the chassis.
> That is why you ground the PC and wear a grounding strap. Done deal.
The strap equalises potential, it will do that whether the chassis is
grounded or not.
> >>>that.
grounded or not.
