Just need some simple advice.
I currently have a TP-Link Deco X60 system setup in my house. Three Decos, all hardwired with either cat5e or cat6. The internet comes into the house through a cable modem, Arris SB6190, then into the main Deco, then into an unmanaged TP-Link 8 port gigabit switch. From there, it’s distributed to the rest of the 4 jacks around the house, connecting the other 2 Decos with Ethernet back haul. Now the issues:
The main Deco keeps rebooting itself randomly, with no rhyme or reason, and I keep seeing Low Power in the error logs.
The modem is full of No Ranging Response received - T3 time-out errors, at least one every day.
The plug everything is attached to in the basement is also on the same circuit as our two chest freezers, if that could affect it at all.
The problems all started last year in December, been running flawlessly until then.
Whatever advice you have helps!
