Hello all, I need your help to decide which graphic card suits my need.
Currently, I have a setup of 1 PC + 3 monitors. I’m using ASTER to create a virtual desktop to enable 2 users to simultaneously working on my PC.
Here is the setup
Since graphic card can only generate output to 2 different display at a time, I link M1 and M2 using ATI Radeon Eyefinity.
So USER A will be using M1 and M2 (paired with Eyefinity), and USER B will be using M3.
But the problem with Eyefinity is that, it will force the lowest resolution of the paired monitor as the baseline, in which my M1 is force to use 1920 x 1080, which causes distortion in height.
I prefer M3 as a standalone monitor, since it has the largest dimension, so I can watch movies comfortably.
So, I’m planning to have a secondary graphic card, which does not need external power, since I don’t have any more power slots in my PSU.
I don't play games, only slight graphic processing, and mostly for coding, browsing and a little Youtube.
Can you guys give me any advice, or even better, any model that is compatible with my current setup?
An older version will do, preferably the one which use the same driver version as my current graphic card (to avoid conflicts in graphic driver).
UPDATED 2019/09/18
So I have bought HD 5670 to be paired. After hardware and driver installation, my Windows 10 crashed on boot up, got BSOD.
Then I did several testing to determine what cause the crash.
Here are what I have tested
Is there anything I can do to make it works?
Thank you very much.
Here is the setup
Graphic Card | XFX HD 5770 1GB GDDR5 | |
Monitor 1 (M1) | Dell UltraSharp 24” Monitor: U2412M | 1920 x 1200 at 60 Hz |
Monitor 2 (M2) | Samsung SyncMaster P2350 23" | 1920 x 1080 |
Monitor 3 (M3) | HP N270 27” | 1920 x 1080 at 60 Hz |
Power Supply | Corsair 750W HX |
UPDATED 2019/09/18
Set Up | Drivers | Result |
HD 5770 on PCIEx 1 | HD 5770 installed HD 5670 not installed | Success |
HD 5770 on PCIEx 2 | HD 5770 installed HD 5670 not installed | Success |
HD 5670 on PCIEx 1 | HD 5770 disabled HD 5670 installed | Success |
HD 5670 on PCIEx 2 | HD 5770 disabled HD 5670 installed | Success |
HD 5770 on PCIEx 1 HD 5670 on PCIEx 2 | HD 5770 installed HD 5670 installed | BSOD |
HD 5770 on PCIEx 2 HD 5670 on PCIEx 1 | HD 5770 installed HD 5670 installed | BSOD |
HD 5770 on PCIEx 1 HD 5670 on PCIEx 2 | HD 5770 installed HD 5670 not installed | Monitors that connected to HD 5770 work fine Monitors that connected to HD 5670 stuck on Windows logo screen. |
