slogger1 :
Yea i would just be getting the one card. I don't think i will be using sli or crossfire.
Ok, do you remember my first post on this thread slogger? If not scroll up and take a good look at it. It's pretty much the same thing that thekidx is recommending. Use that MSI vid card or the one you chose...both are over clocked, and run about the same numbers. So anyways, if you get everything I posted in that first post your good to go.
It's like this. You have a 700w Thermaltake psu...plenty to push that card, you have a E8400...great cpu, and you have a nice case (CM 690). What you do need is what I posted...that hard drive.. 640 WD black 32mb, the vid card....any gtx 285 will do, that mobo I and thekidx posted...they are the same, and then throw that Xigmatek heatsink in with it including the MX-2 thermal compound.
If you get those items, you are set. Then save the rest of your money for when you decide to build a nice shiny new rig later on...maybe a i7..who knows what will be out then.
