Kazul
49
Hey guys,
I'm looking to do an upgrade to my system as it has been a while. I do lots of gaming and like to keep my system up to date though I do not look to break records, just keep up with the average of hardware. I just upgraded my video card so I am now looking else where. My current hardware follows, I am mostly looking at replacing my motherboard, perhaps my CPU, likely I will pick up new RAM along the way. I am mostly looking for recommendations for all the the above. Thanks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131361
Kazul
49
I guess for now lets say I want to keep it under $500. My current full system specs follow, as you see I do have an Nvidia card so I am willing to switch over to Intel.
AMD Phenom II X4 940
GTX470
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
CORSAIR CMPSU-750TX 750W
ASUS M4A79 Deluxe AM3/AM2+/AM2 AMD 790FX ATX AMD
Kazul
49
That is what I am asking you guys. Looking for your opinion on if any upgrades are needed a this point. I do know that my motherboard is very old at this point and my CPU is getting on in years as well.
Hmm the MOBO is deactivated?? Also the 940 may not be restocked. EDIT: Just noticed your nVidia GPU.
[strike]I would either look at the 790FX or 890FX chipset AM3 MOBOs ->[/strike] http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007625%20600007943&IsNodeId=1&bop=And&CompareItemList=22|13-131-363^13-131-363-TS,13-131-655^13-131-655-TS,13-157-196^13-157-196-TS,13-157-208^13-157-208-TS
SLI MOBO - ASUS M4N98TD EVO http://www.newegg.com/Product/Product.aspx?Item=N82E16813131636
CPUs - x4 955 Black or x6 1055T -> http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100006519%2050001028%2040000343&IsNodeId=1&bop=And&ActiveSearchResult=True&CompareItemList=343|19-103-808^19-103-808-TS,19-103-851^19-103-851-TS
RAM CORSAIR DOMINATOR 4GB (2 x 2GB) DDR3 1600 Model CMP4GX3M2A1600C8 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145297
[strike]GPU XFX HD-587X-ZNFC Radeon HD 5870 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card[/strike] http://www.newegg.com/Product/Product.aspx?Item=N82E16814150476
[strike]$230 - HD 5870[/strike]
$140 - ASUS M4N98TD EVO
$145 - AMD Phenom II X4 955
$90 - CORSAIR DOMINATOR 4GB (2 x 2GB) DDR3 1600 Model CMP4GX3M2A1600C8
$100 - CORSAIR CMPSU-750TX
[strike]$740[/strike]
$475
Kazul
49
Thanks for the reply. Do you think that a new PSU will be necessary?
If your PSU is 650W or larger and less than 2 years then you'll be okay. PSUs are rarely understood, and a stressed PSU looses "Wattage" capacity over time. The more stressed the ->shorter<- they last. I keep my PSUs at 50~60% capacity, and only recommend: Single Rail, Japanese Capacitor, Over/Under/Voltage protection PSUs.
Verify your size and read #4 - http://www.thermaltake.outervision.com/
I prefer Corsair, and yes I read the 'bogus' review of PSUs per Tom's -- a lot of people are mad because the review was rigged. You cannot take an 850W PSU that managed to run ~900W+ then say it's not Gold standard because the Max Watt exceeds rated capacity by running it > 850W then say it failed because it was <86% efficient at 105%~110% capacity. If it was at 95% of 850W {~800W} and failed then I'd accept the results.
Kazul
49
I think I actually have the same PSU you recommended and it is only about a year old.
The only question I have regarding your recommendations is between the two CPUs. I have no experience with a 6 core CPU, and I am suspicious that most programs will lack the ability to make use of all those cores. Would I be better off sticking with x4?
Then your PSU is good to go!
Performance, it depends on the Game/App (good link) -> http://www.pcgameshardware.com/aid,746125/AMD-Phenom-II-X6-1090T-and-1055T-Six-cores-on-a-budget/Reviews/ I tend to think ahead, it wasn't that long ago Games used 1 core, next 2 cores, some 4 cores...you get my point. Today ehh... Tomorrow yep.
BTW - if you have a problem, just click the envelope next to my name later, and send a link to a new post. I or someone will have you up and running. Sometimes you need to slightly tweak the NB Voltage {DRAM Voltage - 0.25~0.30v}.
Have fun with your new rig! :sol:
Bobbareeno
Please explain to me how a PSU "looses wattage capacity over time"?? Components age but I would have to argue with that statement. I've maintained multi-million dollar RADAR and navigation systems with power supplies that are stressed to the breaking point daily and they rarely if ever fail. So I guess I'm asking for an engineering explanation on how these PSU's fail when stressed????
^ I don't fell like engaging you in a pointless argument -> http://en.wikipedia.org/wiki/Capacitor#Capacitance_instability
You can maintain a billion dollar facility...if you or the engineers were foolish enough to run your power supplies > 90% then God help us all if your radar systems are critical.
I 'personally' own ~$260,000 in servers and the PSU's are running ~50-70% at peak, and I still have to replace PSUs periodically that are 'thankfully' redundant, the the occasional SAS drive, and RAM from time to time. I 5 year lease and boom out the door for new.
G
Guest
Guest
Hi,
I am running the ASUS M4N98TD EVO with PC3-16000 2000MHz C9 EVO TWO DUAL CHANNEL - http://www.geil.com.tw/products/show/id/246 and can not get the system to boot at the SPD profile for 2000MHz.
I have read others having issues getting this to post at 2000MHz processors. Any advice.
My CPU is:
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz - http://products.amd.com/pages/desktopcpudetail.aspx?id=617&AspxAutoDetectCookieSupport=1
G
Guest
Guest
Thanks. Sorry for not starting a new thread. I figured this was related to the original.
