Archived from groups: alt.sys.pc-clone.dell (
More info?)
On 7 Sep 2005 07:27:34 -0700, "amorphous999"
<jfobrien1458@hotmail.com> wrote:
>Can you give a pointer to whatever patches are necessary to run IIS on
>XP Home? I'd like to be able to develop ASP.Net pages on my home
>workstation, and I've never heard of Apache being able to run ASP.Net
>pages.
This is a writeup that someone else did on the subject. Thank him if
it works. If it doesn't work, sorry. Also try Google search for
Windows XP Home IIS and you will get a lot of hits.
Another writeup is at
http://www.webthang.co.uk/tuts/tuts_server/iis_xph/pippo_xp.asp if you
want to give that a try. Read both, follow the one that you feel is
best. NWEI.
by Richard Sandoz - Certified Java Programmer
(1) locate and edit the file C:\WINDOWS\INF\SYSOC.INF
(2) locate a section called [Components]
(3) find a line like this:
iis=iis.dll,OcEntry,iis.inf,hide,7
(4) change it to this (the iis cab in the i386 xp home folder looks to
be nothing) iis=iis2.dll,OcEntry,iis2.inf,,7
(some sort of ms caching thing keeps sticking back iis.dll when I try
to nuke it. quickly renaming and making hidden dir called iis.dll
seems to thwart, but not worth it, so iis2.dll is good enough)
(5) I grabbed the iis.dl_ and iis.in_ from win2k advanced server cd.
I would guess similar techniques would work from W98, FP, etc. Use
"EXPAND IIS.DL_ IIS2.DLL" from a command prompt Same for IIS2.INF,
place IIS2.INF in C:\WINDOWS\INF and IIS2.DLL in
C:\WINDOWS\SYSTEM32\SETUP
(6) Now when I did "add windows programs" from the control panel's add
new programs, I had IIS options and I could even check em off. yippee
- could not check em off from my xppro cd
I just went with the defaulted ones though (all i needed was iis web
server)
(7) It will prompt you for files. Get em from MS XP Home CDs, Adv
Server CDs, C:\WINNT\SYSTEM32\INETSRV, C:\WINDOWS\I386, etc. (It will
tell you the file it needs, you just need to have a searcher going,
probably the CDs will have all you need)
(8) You can get to your IIS from Control Panel's Administrative
Programs. I stuck in an index.html file and reconfigure IIS to work
like this.
No go
I right clicked on my inetpub folder and did something with shared
folders.
No go
I looked at the event viewer and saw the error of my ways. Go to IIS
and goto Directory Security tab and click Edit button and Browse for
the user setup on my laptop.
(9) Yippee, hello world from
http://localhost
