Question Upgrading cpu and motherboard, need suggestions.
biruz117
17
My current build is a 1650 super with a i7-6700 which I've been told was a bottleneck but it was okay for the games I played, I'm now planning on upgrading the CPU but for that, I'd also need a new motherboard and I'm looking for suggestions up to 200€ . So far I thought about getting the i5-10400F which is at an affordable price given I'm willing to spend 200 for these 2 parts but somebody recommended the ryzen 3 3600 or the ryzen 5 5600, I'm wondering if anyone has any suggestions regarding that. Also, I have a 500W psu which I'm not sure I'll need to change.
Thanks in advance.
Thanks in advance.
Since you are swapping motherboards, you should PLAN to have to do a clean OS install and application reinstall. Get install media, keys, logins, etc for all your software documented so that you can easily do a clean install. Don't assume your current OS "will just work" with the new motherboard and be stuck with no working hardware.
Reactions: biruz117
Thanks for the tip, I'm planning to save everything on another drive, I probably will need another windows key since this one came with my computer and I can't seem to find the activation key, although it is linked to my microsoft account but either way I'll look into it.
