Hey community, after about 6 years it is time for me to upgrade my computer parts, as my otherwise solid MSI Z87 G45 motherboard died after about 6 years. Me and my friend have done everything in trying to find out if the motherboard isn't at fault, which it is, unfortunately.
My budget is 1000 euros
Anyways, here are the components I have put together:
• ASUS ROG Strix B360-F Gaming, S-1151 (24% off) = 105 euros
• Intel Core i7-8700 Processor = 335 euros
• HyperX Predator DDR4 3000MHz 16GB = 108 euros
• MSI GeForce GTX 1660 Ti GAMING X = 345 euros
Should I get a more expensive motherboard, as it is quit cheap? However, it has gotten good reviews
I'd also like to hear if you think I should buy a new power supply, as the one I have (850 Watts) is also around 6 years old.
*Edit: Also, will the mobo fit my Samsung SSD, which requires a sata 3.0 cable? Im almost 100% sure it will, but I figure I'd ask just to be safe
Thanks in advance!
Thanks in advance!
