upgrading...:o i dont know what parts will work..
hannys
7
is this enought info, also what bits are no good..
i need a newmotherboard, its no good, i need a mbo that will work with my parts.
Mainboard : Winfast 761GXK8MB
Chipset : SiS 761GX
Processor : AMD Athlon 64 X2 4800+ @ 2400 MHz
Physical Memory : 8 MB (2 x 4 DDR-SDRAM )
Video Card : Nvidia Corp GeForce 7600 GS
Hard Disk : Maxtor (320 GB)
DVD-Rom Drive : HL-DT-ST DVDRAM GSA-H10N
DVD-Rom Drive : DVD-16X DVD-ROM BDV316E
Monitor Type : ViewSonic VX922 - 19 inchs
Network Card : Silicon Integrated Systems (SiS) Silicon Integrated Systems (SiS)
Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 2
DirectX : Version 9.0c
mobo spec..
2000MT/sHyper Transport™
-DDR400/DDR333/DDR266 DRAM x 2DIMMs, Max2GB
-Integrated SIS graphics
-PCIe x16
-2 Serial ATA w/RAID
-5.1 channel Audio (Realtek)
-10/100Mbps LAN (Broadcom)
-8 USB 2.0 ports
you going to need to upgrade your motherboard before you an do anything else.
You want somthing with this (or close to) this spec.
8gb max ram
4x ddr channels
sata 133 connector
2x ide connectors
2x PC-E x16 slots
SLI compatible
skt 939
ATX form factor
You don't need SLI or two PCI-E x16 slots, and the SATA connectors should be 3Gb/s, not "133". If your hard disk is SATA, you will be able to get away with only 1 IDE connector.
his hdd is a sata 133. can a sata 133 work in a sata 3Gb/s?
yeah, i just found out that one really good GPU is better than two lesser models in SLI, but he already has a 7600, would it be better to dump it and get a better card, or just get another 7600 in SLI?
