I just built a system and ran into some compatability issues. I am now going to RMA the motherboard, ram, and case. The build was
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147127
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128388
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
http://www.newegg.com/Product/Product.aspx?Item=N82E16835207006
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130468
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136032
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
The motherboard and case had a different front panel connector configuration. The computer would boot up unless I turned the power supply off. It also would not stay off. I also want to oc the cpu to at least 3.0. I could only do this with 2gb of ram. Would not work with four. The ram... well the ram just plain stank. Would only work at factory settings with auto fsb. Any change to fsb it would bsod. I want to replace the mb, ram, and case with these
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147125
Does any one see any issues with this build? Will I be able to oc to at least 3.0 with all 4gb of ram? O ya, I'm using the newest windows 7 RC x64. I am on a strict budget. Kinda already went over, o well. Thanks for any advice.
-Randy
P.S. does anyone think that http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358 is better? It does have the 2 pcie slots. I will probably never use it but it's nice to know I would have the option. Not to mention the dual lan ports.
-Randy
