Ok firstly sorry if this is in the wrong place or if I shouldn't have had caps in the title but I seem to have been hit by a very strange virus that has completely crippled my laptop. Effectively every single file or program on the computer (literally) has begun displaying the error message: windows cannot find the program to open this file, please select one from the list. I am able to run firefox because I know where to find the firefox directory and select the .exe to run it with ut anything even vaguely system related I have no idea what to do. I wold post a screenshot but paint is appantly an unrecognised file and i have no idea where to find its .exe. I have had a nasty virus a long time ago but solved it with system restore. However when system restore becomes an unrecogniseable file and I dont know where to find its .exe then this becomes a lttle difficult. Does anyone knowwhere I could find system restores .exe file as then i should hopefully be able to try to get this sorted. This has happened across the laptop for all users and safe mode does nothing. Any suggestions would be greatfully recieved (except those that suggest solutions involving using run as this is an unrecognised file type
