usb 2.0 card problem with windows xp pro /a7v266-e
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Is there anybody who can help me?
I have a asus a7v266-e motherboard with XP sp1, with latest biosupdate,
latest VIA 4in1 drivers. I am trying to install a BELKIN USB 2.0 PCI
(f5u220) pci card. But whatever i try, it keeps signalling that the usb
controller(s) can' t be installed. I already tried to change the PCI slots,
i've removed my Audigy sound card but the problem stays. i've uninstalled
the onboard usb 1.0 controller, another usb 2.0 card (ALI) nothing helps. I
tried to manually install usb 2.0 drivers without any result.
i can't find the right answer with ASUS.
So any ideas around ?
Ronald
In article <c_9Jc.139522$3N6.114507@amsnews05.chello.com>, "ronald
> Ronald
Please include the exact error message you see, when doing the install.
Paul
In article <nospam-1407041407480001@192.168.1.177>, nospam@needed.com
> > Ronald
> Paul
For example, if you see:
"An error has occurred during the installation of this device.
The data is invalid."
then see this article:
http://www.pcbuyerbeware.co.uk/Tips.htm#probleminst
You might want to check in groups.google.com for other user experiences.
Some people seem to have trouble getting that card to work.
It is like the hardware just isn't detected at boot. You
might look in Device Manager, to see if anything changes, on
the boot after the card is plugged in.
HTH,
Paul
After the new hardware found message comes the message that the hardware
could not be installed, "the hardware is wrongly configured"(translated from
the dutch version of XP)
"Paul" <nospam@needed.com> schreef in bericht
news:nospam-1407041407480001@192.168.1.177...
slots,
uninstalled
helps. I
> > Ronald
> Paul
In article <UgBJc.40974$qK.38097@amsnews02.chello.com>, "ronald stougie"
Does that mean the same thing as "The data is invalid." ?
babelfish.altavista.com says = "de gegevens zijn ongeldig."
Paul
> slots,
> uninstalled
> helps. I
> > > Ronald
> > Paul
Yes!!
It's working i followed the procedure in
http://www.pcbuyerbeware.co.uk/Tips.htm#probleminst and the installation was
done all right. Thank you very much.
Ronald
news:nospam-1707040509180001@192.168.1.177...
from
> Paul
biosupdate,
usb
> > slots,
> > uninstalled
> > helps. I
> > > > Ronald
install.
> > > Paul
