Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Never mind. My old USB 1.1 hub had me fooled into thinking the rear ports
were only functioning at the slower speed. All systems go now.
"rc" <nunya@business.net> wrote in message
news:4h4Bd.4685$6V1.3827@bignews3.bellsouth.net...
> After many frustrating hours I finally relented and downloaded SP2, which
> solved the problem--almost. Windows recognizes the controllers, but the
> onboard USB ports (rear) are only USB 1.1. The front ports are recognized
> as and work as USB 2.0. If I'm not mistaken, all of the USB controllers
> on this board should be 2.0. Any suggestions?
> "Venom" <Viper@Mailhouse.com> wrote in message
> news:Qn2Bd.96444$K7.14561@news-server.bigpond.net.au...
>> The drivers are in SP1. You are correct.
>> "end user" <locust@gregarious.com> wrote in message
>> news:3aj6t0hgdm91ik54ins5i848rfd23pb609@4ax.com...
>>> I believe that usb 2.0 hispeed only comes with XP sp1 or higher.
>>> Could be wrong.
>>> Locust
>>> On Wed, 29 Dec 2004 17:16:41 -0500, maduser@bagspammers.net wrote:
>>> >On Wed, 29 Dec 2004 15:53:14 -0500, "rc" <nunya@business.net> wrote:
>>> >>I can't get Windows to recognize the USB controllers on this
>>> >>motherboard
>> as
>>> >>USB 2.0. They are configured as USB 1.1 and work fine, but this board
>> is
>>> >>advertised as and all the literature refers only to USB 2.0.
>>> >>What do I need to do to get Hi-Speed USB? I have tried all the BIOS
>>> >>settings and downloaded files from Microsoft and Intel with no luck.
>>> >>Thanks for any help.
>>> >>Robert Cozine
>>> >If you're running XP, open device manager, expand the Universal Serial
>>> >Bus controllers item, select one of the existing USB Host Controller
>>> >entries, right click and select Update Driver. Follow the prompts, and
>>> >you should see the following new entry under Universal Serial Bus
>>> >Controllers:
>>> > Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
