They have to be plugged into the motherboard header. This is what it looks like: http://www.techpowerup.com/reviews/ASUS/M5A97_EVO/images/usb3_header.jpg.
It must have been unplugged somehow. It happened to me a couple times.
Yeah I think I can see a loose connector, my case is see through at the side, I just ned to plug it back in to the front
If all is plugged in, check to see if the ports are enabled and active in device manager, might also check that you have the latest mobo USB drivers for your OS at the mobos web site
Once again, you need to plug the 3.0 connector into your motherboard, then insert the DVD that came with your motherboard and install the USB 3.0 drivers for it to work. If after that it doesnt, you may have a bad USB 3.0 slot on your mobo.
Ok thanks, I got my pc about a year ago so the drivers are already installed, I dont think the port is broken because it was working before and the pc is pretty new, I really appreciate the help
Doubtful but possible, may be a corrupt driver or the case port itself gone bad
Okey So I found this USB3.0 cable that was not connected to anything, but it was coming were the usb ports were. I dont know were I should connect it to on my motherboard because I cant find a port that fits ????
