My case doesn't have any USB C ports built in.
No USB 3 ports, for that matter.
So, I got this:
https://www.newegg.com/p/35G-0028-0...5" front bay usb 3-_-9SIACJF6NV5793-_-Product
I have a floppy drive mounted with a 34-pin floppy to USB converter (https://www.ebay.com/itm/1-44MB-3-5...180466&hash=item23b86cb13a:g:z-4AAOSwQg9b0m-t) and since I wanted to mount a USB-C port in it, I figured "why not get a USB-C insert for this port and then set the spare USB-A port for my converter? That way I don't have to run the cable out the back of my case."
I can't find one that has the USB-E internal motherboard port thingy on it, though or with a 20-pin header that I can adapt.
Does anyone know if such a thing exists, and if so, where I can find it?
And yes, I know that my motherboard (Asus ROG Strix B350-F Gaming) doesn't have a USB-C header, but either of the boards I plan to upgrade to does.
So, I got this:
