USB device problem with P4P800E Deluxe M/B
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a USB 256MB flash drive. It works fine in an old Win98SE
system. It works fine in the backplane connectors on my new P4P800E
Deluxe WinXP system. But if I insert it in either of the front
connectors in the case I get the following error balloon:
USB device not recognized. One of the USB devices attached to this
computer has malfunctioned, and Windows does not recognize it.
Clicking on the balloon calls up a table with the correct port
identified, and the above message repeated along with the advice:
Try reconnecting the device. If Windows still does not recognize it,
replace the device.
Now, I'm not about to replace the device - it works fine. And if
there is a fault in the port it's a very subtle one, because my
digital camera is recognized on the same port & I can download with no
problems. Any suggestions? It's a pest to pull the computer out to
access the back ports whenever I want to use the USB drive.
Dave Gillingham
To email me remove the .private from my email address.
I had a bad experience with the front USB port)s which
literally burned the USB optical MO ( magneto-optical )
drive I plugged in. The drive was completely dead, just
in a matter of one or two seconds.
I don't trust the USB front port, whatever way.
Just get a 4-port or 2-port USB hub to connect from the
back and you can plug in easily. It also removes any headache.
"Dave Gillingham" <dewg@private.optusnet.com.au> wrote in message
news:fiul11hmiboh02d1e8r1e987tivu8qtisu@4ax.com...
> replace the device.
> Dave Gillingham
sounds like maybe you've pin the cable wrong...it may have been enough
to cook it...
Was it a gang plug or 8 separate pins going to the front of the case ?
ñíñjà¤têç
-----END-PGP-SIGNATURE-----
On Tue, 22 Feb 2005 19:38:19 +1000, Dave Gillingham
>replace the device.
>Dave Gillingham
The cabling is fine - I can download from my digital camera with no
problems. It's simply seen as another detachable storage device.
>to cook it...
> ñíñjà¤têç
>>replace the device.
>>Dave Gillingham
Dave Gillingham
