Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Drivers for cameras, cellphones and such will be found at
the maker's web site, e.g. Kodak, Canon, Fuji etc, or
Motorola, Nokia. Bluetooth is a standard and should be
automatic. If there is corruption with the USB drivers,
often caused by plugging in a device that needs a driver,
such as a printer or scanner before that driver has been
installed, you can clear the USB list of drivers using the
device manager to remove the USB ports, hubs and devices,
then reinstalling each device properly.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"J-Dee" <JDee@discussions.microsoft.com> wrote in message
news
😀AAFE177-97DF-4177-B323-88DF6DD0A2CE@microsoft.com...
|I had a similar issue, it seems to give power but no access
to the device, as
| the other guy said you need drivers and theres usually 2
ways of them being
| found, either there on your motherboard which will mean
the drivers will be
| on the motherboard disk, or... if you have a seperate pci
card with usb ports
| you should have a usb cd for that card.
| "Jim Macklin" wrote:
| > You need drivers for many USB devices, XP (even SP2)
doesn't
| > have every driver for every device.
| > "Anirudh V Kulkarni" <Anirudh V
| > Kulkarni@discussions.microsoft.com> wrote in message
news:9EC32A3F-19A7-4E82-8B72-4C28C9292BE2@microsoft.com...
| > |i have a p3 running on xp sp1. the windows reports the
usb
| > controller and hub
| > | are working fine. i connected a samsung mp3 player and
it
| > worked. but none of
| > | the other devices( Bluetooth dongle, kodak camera,
nokia
| > communicator 9300)
| > | work. will be grateful for any help.
