Hey guys, looking for a little help solving a dilemma:
I recently put together a new system:
Windows 7 Home Premium 64 bit
Asrock 990fx Extreme3 AM+3
AMD FX-6100
16GB Corsair Vengeance Ram, DDR3 1600 (4 x 4GB)
1TB Seagate 7200.12 sata II 3.0GB/s
Sapphire Radeon HD 6770
Xigmatek Loki H.S. dual 92mm fans, push/pull config.
Asus Blu Ray/DVD/CD
Corsair CX500 PSU
I initially had to install my ram in the A2, B2 slots to get the system to post. I only installed 8GB to start and changed the default settings in the bios from 1333mhz to 1600mhz then install the other 8GB in slots A1 and B1, and everything worked fine. I did a clean install of windows and the 200+ updates that came with that and installed all my drivers and hardware updates. As you can imagine, my system restarted quite a few times. Had absolutely no problems and everything was working fine. Since I plan on overclocking eventually, I ran prime 95 for a few hours to get some bench marks for operating temps and to make sure my heat sink seated good. I also fired up a few current video games (Skyrim, Fallout LV) to push the video card a bit, again just to kind of bench mark the card at stock settings.
All of this took approx. 6-7 hours and the system preformed flawlessly. Did a little light gaming that night and all-in-all the system was on for a good 10+ hours and everything was looking really good. Solid temps on everything and performance that was right around what I expected. Woke up today and took the computer off my workbench and moved it over to my desk, plugged everything in and hit the power button..... and to my surprise, no joy, wouldn't even post. =(
The ONLY thing different from the previous night was that I plugged in a Rosewill RHUB-310 USB2.0 7 port USB hub. I unplugged the hub and tried to have my ram in different configs (A1,B1....A1,A2......A2,B2....B2,B2, ect.), I even went one stick at a time and could never get the system to fully load windows before crashing. Some times it wouldn't even post, other times it would get to the "Starting Windows" splash screen before crashing.
I am now believing my ram may be compromised and am going to grab a few new sticks tomorrow from a local shop and give that a try. But I'm wondering.... is this USB hub the reason??
I ask because my old reliable duo-core system had the exact same issues shortly after I plugged that hub into that system. I swapped out that system ram and it has run fine ever since, but I haven't used that hub with that system since I installed the new ram. I never imagined that a hub could case such a problem, I just figured my old system suffered from a random ram failure. But the similarities of both of these systems ram failures and the fact that the hub seems to be the only common piece of hardware makes me very suspicious.
I just want to know if anyone has had any issues like this or heard of anyone else having this kind of problem. If so I'd like to know, as I'm on the verge of sending a very unflattering e-mail to Rosewill, since (if my hunch is correct) this little $15 hub has now cost me over $100 in ram. The hub is only 3-1/2 months old so if it is the culprit, I will be expecting Rosewill to offer up some type of reimbursement.
Anyways, thanks for reading through my post and for any advice you have to offer.
AMD FX-6100
Asus Blu Ray/DVD/CD
Corsair CX500 PSU
