USB Hub weird conflict
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Installed win2000pro. Everythings great! but...when I shutdown, it goes thru all the motions, but hangs with a blue screen and frozen cursor when finished. If I unplug my USB HUB, it works fine. What do I do with that problem?
d....
first you check if your hub is win2k compatible by checking MS' HCL (hardware comaptibility list).
If it is, you make sure you have the latest driver for it.
failing that......hmm
