USB Lexar Flash Drive
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I recently purchased a Lexar JumpDrive Secure. I am not using the
encryption software that came with the drive, I would like to use it
as a regular flash drive.
Works fine, the only problem is WinXP mounts it as a Local Disk. I
would like it to mount as a removable disk. Does anyone know how to
re-partition and format this flash drive so it will show up as
removable media?
> removable media?
Are you sure XP mounts it as a local disk. Or, does your system mount it
as a local disk? Check on someone elses system before you come to a
hasty conclusion.
Incorrect mounts sometimes happen with XP.
courtney sends....
Courtney <a@b.c> wrote in message news:<uggkd.75658$%x.70741@okepread04>...
> > removable media?
> hasty conclusion.
> courtney sends....
Three Xp-pro systems and two Win2000 systems all mount it as a local disk.
Windows 2000 and Xp both mount it as a removable drive. The only thing is
the fact that the drive letter gets assigned as a "first come first serve"
method where the letter changes.
"James Watchman" <online_avenger@hotmail.com> wrote in message
news:59f849e1.0411100534.258c8f0e@posting.google.com...
>> > removable media?
>> hasty conclusion.
>> courtney sends....
