G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I've been searching the internet for two and a half days now. And to
my surprise it actually seems to be a very common problem that nobody
has an answer to.
I've bought a LaCie 160GB external (USB) disk to backup my data, but I
can not access it using XP (XP home, SP1, SP2 and USB2.0). The only
thing I get out of it is a line in the USB tree saying 'LaCie' (when I
use start>execute>devmgmt.msc). But with an exclamation mark. When I
use diskmgmt.msc, it doesn't make mention of it at all. Even when I
rename my DVD en CD to X: and Y:.
The software that came with the disk doesn't work and is aborted (not
too weird as it is pre XP only and XP has native drivers for it).
The disk works all right when I try to use it on my old computer
(Pentium 1). But that one has a 400MB hard disk that I can backup
using a CD. So... no need for a 160GB LaCie there.
Now, when I use a 128MB USB key, it doesn't work either. The stick
doesn't even find it's way to the USB devices root.
I know the USB is working, because I've tested it with a tablet, a
scanner and a camera (which is also external storage). The only
difference is that these all came with their own drivers.
As said, it's a common problem, that nobody seems to have an answer
to. This really confuses me.
I wish it was sufficient for a device to just insert a CD into the
computer, press 'OK' and the system was ready to work with only 4 or 5
minutes later. Plug and play seems to demand for system reinstalls,
BIOS changes, motherboard chip driver updates and a week of time to
spare.
has an answer to.
spare.
