[SOLVED] USB Ports Do Not Work
mileshicks445
Commendable
Sep 18, 2018
This happened out of nowhere. I booted up my PC, and after about 10 minutes of using it all of my USB ports stopped working. The RGB on my mouse and keyboard would flicker off and on, and I kept getting an error from Windows saying that my USB device is malfunctioning. When I unplugged all my USB connections the error still persists and now I can't login back in to fix it.
Intel i9 10900k
GTX 1080 Ti
MSI Z490 Gaming Edge Wifi
Corsair K-95 Platinum
Razer Viper Ultimate
Windows 10 Home
Make sure that standoffs were install between the motherboard and the case and that the are in the apropiarte location.
Unplug all USB cables connected into motherboard headers, then check if the motherboard USB ports on the back are working.
