Hello friends, I am writing to you from Chile and using a translator, my strong point is not English, I will tell you that I have decided to restore an old PC with an Asus board, but it turns out that USB data transfer does not work anymore, but the ports do supply power. Apparently it is a recurring defect on this board model, could someone solve this problem???
Model
Brand
ASUS
Model
M2NPV-VM
Supported CPU
CPU Socket Type
AM2
CPU Type
Athlon 64 X2 / Athlon 64 FX / Athlon 64
FSB
1000 MHz
Chipsets
Chipset
NVIDIA GeForce 6150
South Bridge
NVIDIA nForce 430
Memory
Number of Memory Slots
4x240pin
Memory Standard
DDR2 800
Maximum Memory Supported
8GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express x16
1 x PCI Express x16
PCI Express x1
1 x PCI Express x1
PCI Slots
2 x PCI Slots
Storage Devices
PATA
2 x ATA100 4 Dev. Max
SATA 3Gb/s
4 x SATA 3Gb/s
SATA RAID
NV RAID 0/1/0+1/5 JBOD
Onboard Video
Onboard Video Chipset
NVIDIA GeForce 6150
Onboard Audio
Audio Chipset
ADI AD1986A
Audio Channels
6 Channels
Onboard LAN
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
LPT
Video Ports
D-Sub + DVI
USB 1.1/2.0
4 x USB 2.0
IEEE 1394
1 x IEEE 1394a
Audio Ports
3 Ports
Internal I/O Connectors
Onboard USB
4 x USB 2.0
Onboard 1394
1 x 1394a
Physical Spec
Form Factor
Micro ATX
Dimensions (W x L)
9.6" x 9.6"
Power Pin
24 Pin
Features
Features
HDTV / AV / AS output module include.
Packaging
Package Contents
M2NPV-VM
User Manual
Driver Disk
Rear I/O Panel Shield
FDD Cable
2 x IDE/PATA Cable
2 x SATA Cable
Power Cable
IEEE 1394 Bracket
HDTV/AV/AS Output Module
