usb2 & usb firefly drive problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
i have an hp pavilion laptop ze4400, that didnt come with a usb2.0 port. i
came with winXP home which i am using.
i recently bought a smartdisk firefly 20 usb drive. i had/have it working
on my desktop fine (which has 2.0 ports).
i plugged it into my laptop a few times & it seemed to work ok, can get to
the drive, see it in device mgr & manage|disk management.
but i wanted more speed so i bought a 2.0 card to use install of the
built-in 1.1 port.
i have installed the updated ALI driver and that all went smooth. i plug
the firefly it (most of the time it is recognized) and it will tell me it
sees a toshiba drive (which it is) and it thinks thinks are hunky-dory. but
when i go to windows explorer the drive isnt there. when i checked
mange|disk management the drive isnt there. however, the device manager
shows it fine. i have no ? marks or ! marks in the device manager.
any ideas on how i can get this darn thing to let me get to the drive with
the high-speed 2.0?
thanks.
jim
I had troubles installing a USB2 card on top of existing on-board USB1 -
conventional wisdom from this NG was to go to Device manager, UNINSTALL
every instance of USB/USB2, re-boot, and XP then automatically finds and
re-installs the USB ports correctly - and it worked.
One thing - BE AWARE - if you have USB mouse and/or keyboard - first replace
with conventional mouse/keyboard - I forgot that - won't bore you with the
probs THAT caused! All OK now.
HTH - Len
"jim sturtz" <jsturtz@sturtzs.com> wrote in message
news:%23eVnA939EHA.2568@TK2MSFTNGP11.phx.gbl...
> built-in 1.1 port.
> but
> the high-speed 2.0?
> thanks.
> jim
well, tech support @ smartdisk finally replied, there belief was the 2.0
wasnt picking up power/enuf power from the mobo. suggested buying a powered
external hub ($35) and that fixed the problem. i guess all 2.0 pcmcia cards
are not the same or the mfg can decide whether to supply power to the
cardslot.
anyway, that fixed it.
"yabbadoo" <lsdolby@ignore.ntlwor.com> wrote in message
news:%23jtL9t99EHA.1408@TK2MSFTNGP10.phx.gbl...
replace
> HTH - Len
i
working
to
> > built-in 1.1 port.
plug
it
> > but
with
> > the high-speed 2.0?
> > thanks.
> > jim
