I currently have a surface studio (gen 1). It is a wonderful AIO computer with some outdated hardware. I have swapped the original ssd+hdd hybrid to pure sata ssd, which leaves an empty m.2 port. My current plan is to upgrade the pc to Wi-Fi 6 by using the empty m.2 key m port. There are several adapters that convert m.2 key m to key a/e or mini-PCIE so I can plug in the wifi 6 adapter (since no network adapter use m.2 key m) but I'm not sure if they will work.
Option 1: m.2 key m+b to mini-PCIE adapter for wifi/bluetooth
https://www.amazon.com/NGFF-mSATA-Mini-PCI-Converter/dp/B078NS9R2V
Option 2: m.2 key m to m.2 key e/a/a+e adapter
https://www.aliexpress.com/i/4000274478342.html
www.hwtools.net
Will they both work on wifi 6 card? Can they provide full 2400Mbps/8=400MBps speed?
Which option is better?
M2E (M.2 Key A Wireless Card to M.2 Key M Adapter)
