I recently built my son a gaming computer and spent a considerable amount of money on the graphics card the GForce GTX Titan. My son wants to use his 32 inch Sony LCD brava via hdmi wich is 60mhz. It is set to gaming, and the profile is set to PC through the hdmi. The problem? The graphics are not as good as his Xbox using this setup, my question is why? I have read a lot about settings and mine are all correct for what I have, it seems to me if Xbox can connect to TV via hdmi with a perfect picture why can't a $900 video card do it? There is no special settings to change to get it to work, so I guess I am just not understanding why the graphics don't look as good as xbox on the tv via hdmi. If anybody can explain this to me I would appreciate it. As of now it looks like I will have to buy a hd gaming monitor, which I didn't foresee. The graphics work ok, but for the money I spent I want them to pop and I'm not seeing that with this setup.
SOLVED
The problem was a bad hdmi port on the graphic card, I had to RMA it and got a new replacement and problem solved
SOLVED
